6/27/2011 2:11 PM | |
Posts: 13 Rating: (0) |
thank you for your help i have aproblem .......i need to change the on time duration -"duty cycle of pwm"-while run time and change this value every time cycle - time cycle = 150 msec - check attached file for detailed information .. waiting your answer .. Splitted from Sample program: PID Lean PWM generator for standard IO. |
Last edited by: O_Moderator at: 6/28/2011 8:05 AMnew subject after splitting Last edited by: mohamed gabal at: 6/28/2011 1:09 AM |
6/28/2011 8:09 AM | |
Joined: 4/24/2009 Last visit: 8/20/2024 Posts: 2682 Rating: (135) |
Thread closed, because question is already published in the following thread I have problem when I try to connecting online to cpu. Best regards O_Moderator |
