12/22/2010 10:03 PM | |
Joined: 9/27/2006 Last visit: 3/20/2025 Posts: 12344 Rating:
Hello jm1983; From the documentation available trhough their site, Enraf does not provide a profibus-DP connection. As it is part of the Honeywell process control offerings, you should look at the following link that states it can provide a Modbus gateway (you could access it serially with a CP 341 + Modbus dongle, or a ET 200S 1SI Modbus module) or through OPC, directly from your SCADA package: http://hpsweb.honeywell.com/Cultures/en-US/Products/TerminalAutomationProducts/NetworkInterfacing/default.htm Hope this helps, Daniel Chartier |
9/7/2016 12:16 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating:
New question published by anansree is split to a separate thread with the subject Hot swapping, Fault Tolerant and redundancy S7-400H system. Best regards |
