6/7/2010 5:23 PM | |
Posts: 2964 Rating:
Hello.... I would prefer if you have Simatic Manger Step7. Connect it and see why the errors have triggered. If it requiresto clear the PLC you can do the same via Clear/Reset.... As our friends told in the pervious posts you can clear the same through S4 rotary switch. I have document prepared for it you can see the same for informations... Hope this will be useful..... Ekalavya AttachmentPLC clearing.pdf (242 Downloads) |
