12/13/2023 11:47 AM | |
Posts: 3 Rating:
Hello, I want to access a mnemonic in a datablock, with the path specified as follows: 'DB_D_IO_THIS{i}.Mnemonic'. I want the variable 'i' to take its value from the path 'E1.Pos[0].Entr0_Av_Pos[0]'. I've tried the code below; it works the first time, but when I change 'i', the output value doesn't change. [snip] ------------------------------------------------------------------------------------------ AttachmentLog.txt (482 Downloads) |
Last edited by: The Helping Hand at: 12/13/2023 12:01:56New subject after splitting, Text optimized and Code attached as txt-File |
