4/30/2009 9:42 AM | |
Hi In WinCC V7.0 you can create Faceplate-Typs, which works how a Faceplate. OR You conect one property of your object to the structure tag. read out the linked variable by a script search in the string for the last point change after the last point the varible read out the value and set the new property. But, linked variabe you need a variable which change often. Then you can run the script "object change". regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
5/16/2009 10:19 AM | |
Posts: 69 Rating:
Does anybody khow about this problem ? Helpp! |
