8/25/2009 11:18 AM | |
Joined: 7/17/2008 Last visit: 10/25/2013 Posts: 34 Rating:
Hi Rezajan55, You cannot use this CPwith that protocolbecause isserial interface protocol. If you need to use IEC 60870-5-101, you have to use a Serial CP441. If you need to use Ethernet you could use IEC 60870-5-104 that is the IEC 60870-5-101ethernet transportimplementation.. Siemens has libraries for these protocols, you can find more info here: http://support.automation.siemens.com/WW/view/en/37706265 Hope this helps regards |
