5/2/2017 4:34 PM | |
Posts: 42 Rating: (3) |
Good afternoon to all, I would like to ask a question about datalog to 1200 because I have some troubles. I have a FB (FB15 in picture 1) where inside i wrote the logic and where there is the datalog blocks (open, create, write, close) as local instances. I wanted to pass the DB to log from ouside, so I feed the write FB with a Variant in/out variable. (Picture 2, DB_Sorgente variable) The detail of DB is in picture 3. I have some UDT that simple define a DINT and a LREAL. Mi problem is that when I trig the Datalog create, I get 8C51 error that mean incompatible data in datalog to store. I tried with a simple DB with a bunch of heterogeneus var and is working fine that time. Only when I try to add a UDT things goes wrong. Do you have any Idea why this happen? I tried to search along manuals but I dindt able to find any valuable solution. Thankyou very much for your help. Luca V. AttachmentDLError.zip (42 Downloads) |
