1/11/2012 12:48 PM | |
Joined: 10/7/2005 Last visit: 6/6/2023 Posts: 2966 Rating:
Hello JB2020 SFC51 with SSL-ID W#16#00B2 will give you the info you are after. Check out SSL-ID W#16#00B3 too, it will allow you to read Diagnostic records from local cards as well as DP Slaves (wheras using SFC51 with SSL-ID W#16#00B4 is basically the same as using SFC13). I hope this helps |
1/11/2012 10:33 PM | |
Posts: 9 Rating:
Thanks fritz, I'll try it out. |
