10/30/2013 8:06 AM | |
Joined: 3/20/2013 Last visit: 3/27/2025 Posts: 676 Rating:
Hi bijan, as far as i know you can not project in NetPro a tcp connection from/to the im151-8 pn/dp. you can only use the open user communication if you want to communicate with tcp/ip (refer to Technical Data. for a connection to wincc you are also able to project a hmi-connection. greetings, fafner |
Best Regards, |
