8/22/2011 3:18 PM | |
Joined: 10/7/2005 Last visit: 6/3/2023 Posts: 2966 Rating:
Hello AXIS to start with, the latest IM151-8 PN/DP CPU (6ES7151-8AB01-0AB0) has a maximum DB size of 64 KByte (see HERE for more). This limit also applies for Instance DB's, so you have plenty of space left in your FB to declare STAT variables. If you have an olderIM151 it may be less, punch in its part number at https://support.automation.siemens.comto find it technical spec or go online in your CPU and check the performance data tab of theModuleInformation. Could it be that you perhapsnot recreated the FB's Instance DB or that you did not download it? (it's the only explanation I have for your problem). I hope thishelps |
Cheers |
