10/25/2015 11:28 AM | |
Joined: 10/18/2014 Last visit: 4/3/2023 Posts: 92 Rating:
Hello I am using IM151 - 8 PN/DP CPU with 2 AI card (6ES7134-4GB01-0AB0) I am connecting mA source to module directly to below terminals 1- M+ 2- M- values are not getting at any input, i am using 8 modules total & facing same problem to all cards. please help us on priority Ganesh Dighe ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 10/26/2015 10:19:18 AMNew subject after splitting Ganesh-0220 |
10/26/2015 9:10 AM | |
hi, are you sure that you have a 2-wire-transcucer? What is your "mA source"? A 2-wire-module is powering the the transducer(see the manual page8). If your transducer is already powered you have a 4-wire transducer. hope this helps, regards,
