3/25/2009 9:06 AM | |
Joined: 5/8/2006 Last visit: 10/16/2024 Posts: 1085 Rating:
Hi You should use the option "Reset to factory settings". Maybe the following FAQ will help you: http://support.automation.siemens.com/WW/view/en/26437978 Bye |
3/25/2009 9:09 AM | |
Joined: 4/24/2006 Last visit: 2/7/2025 Posts: 8836 Rating:
Dear Thavas, The only way to use the panel again, is to perform an OS update with option 'Reset to factory settings' Here is a link to manual http://support.automation.siemens.com/WW/view/en/26248558 See chapter 7.7.5, here is described how to perform. I know it could be difficult, you should try. At least it will work. Best regards, Wizard |
4/17/2009 9:18 AM | |
Hi Thavas, Just to be sure: Your PC is connected to panel using a Cross Cable? Best regards, Wizard |
4/24/2009 9:42 AM | |
Hi Thavas, Perhaps this link might give you some hints: http://support.automation.siemens.com/WW/view/en/35677293 Best regards, Wizard |
