6/9/2009 11:22 AM | |
Posts: 261 Rating:
Dear all, We are having a MP377 (6AV66440AB012AX0) and WinCC flexible 2007 (6AV66130AA572CA5). The technical data sheet showing the compatibility in between these two. (http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=6AV6644-0AB01-2AX0&caller=view). Now the image file of the supplied MP is 1.0.2.0. In Wincc flexible 2007 S/W we found the image file for MP377 is 1.0.0.0. Image file 1.0.2.0 is not available. Please help. With best regards ddg |
6/10/2009 7:46 AM | |
Joined: 3/21/2006 Last visit: 7/12/2023 Posts: 10221 Rating:
Hi, I guess you already tried Hardware Support Packages (HSP) for WinCC flexible 2007. If I am no wrong with this package you'll receive 1.0.1 image of MP377. I suggest you to contact with Siemens Office in your place... Best regards Hristo Mihalev |
6/10/2009 8:44 AM | |
Hello again, In all documents seems that MP377 is "compatible" with WinCC Flex 2007. Look also in Which Engineering Software can be used with which panels? Best regards Hristo MIhalev |
6/10/2009 8:47 AM | |
Joined: 4/24/2006 Last visit: 9/14/2023 Posts: 8592 Rating:
Dear ddg, Please have a look at this link: http://support.automation.siemens.com/WW/view/en/27774824 Here you see, you can program MP377 using WinCC flexible 2007 standard Maybe, these links are useful: http://support.automation.siemens.com/WW/view/en/21742389 http://support.automation.siemens.com/WW/view/en/28735883 Best regards, Wizard |
Last edited by: Wizard at: 6/10/2009 8:48 AMOooops, just too late. ;-)) I will try to type faster next time. |
6/11/2009 12:03 PM | |
Posts: 261 Rating:
Thanks to all We solve the issue.Great help from forum. With best regards ddg |
