7/17/2022 2:27 PM | |
Joined: 4/28/2015 Last visit: 9/29/2023 Posts: 567 Rating:
There is no such image prebuilt, but you can create one from https://github.com/siemens/meta-iot2050/. Basically replace iot2050-image-example with iot2050-image-base in https://github.com/siemens/meta-iot2050/blob/master/kas-iot2050-example.yml. Note, though, that mraa and currently also node-red-gpio are customized (patched) packages that cannot be found elsewhere with the full support for the device. |
7/22/2022 8:57 PM | |
Joined: 4/28/2015 Last visit: 6/16/2023 Posts: 42 Rating:
Thanks for the answer. I'll test it next time and report back. Best regards |
