6/7/2014 6:11 PM | |
Joined: 7/2/2008 Last visit: 9/30/2024 Posts: 928 Rating: (309) |
Helloachref.bouabana, You can't get your 3D block in WinCC flexible directly as an object. You have to render your model to create a picture that you can import in WinCC Flexible. If you are going to animate this block then you will have to render it in ACAD as many times as many colors/attributes you want. In WinCC flexible you will have to import all rendered pictures and use animation attributes to hide and show the rendered pictures based on tag values/status. Best regards, H-H
