8/7/2017 8:24 AM | |
Posts: 648 Rating:
Hey Thomas, this links could be helpful: Migration Guide; helps you to migrate from WinCC flexible to WinCC (TIA Portal) https://support.industry.siemens.com/cs/ww/en/view/77430539 What do you do if, when migrating a WinCC flexible project to WinCC TIA Portal, the procedure aborts and you get an error message? https://support.industry.siemens.com/cs/ww/en/view/109486003 How can you transfer global libraries from WinCC flexible to WinCC (TIA Portal)? https://support.industry.siemens.com/cs/ww/en/view/57025382 With best regards rh1990 |
