8/5/2008 3:07 PM | |
Posts: 178 Rating:
When using import function in Graphic designer- I can preview *.emf ok. However when I OK Import, the drawing is not displayed(inserted) correctly. I am using CorelDraw to generate picture and saving them as emf files. Any idea? Thanks.... For future ref, what is a suggested graphic package? Attachmentimport.zip (50 Downloads) |
8/7/2008 4:40 PM | |
Posts: 2661 Rating:
Can you post youremf and pdl? I tried on my machine with my custom emf and it works fine. Regards |
8/7/2008 4:58 PM | |
Posts: 178 Rating:
Import of *.emf does not import graphic correctly. If I insert a Graphic object (same emf file)it works ok. AttachmentGraphic2.zip (47 Downloads) |
8/14/2008 4:34 AM | |
Posts: 2661 Rating:
For some reason the Graphics Designer does not like the format of the emf file you created! As a work around, I opened the file from mspaint and copy/pasted to the PDL and it works! See attachment. I have seen these incompatibilities before (between various graphics programs). Regards AttachmentNewPdl3.ZIP (55 Downloads) |
