2/24/2009 6:10 PM | |
Hello loritod Sorry, i didn´t understand your problem. You has a picture with an independent (picture) window. When you start up the runtime, the picture and the window appears, rigth? Witch version you have? Is the picturewith the window the start picture? Is the window attribute "visible" true when you start up? Has the window a picture? (as i understand yes) I use picture windows so, that i have to click on a button to get the window visible, so it can not shown by start up the runtime. How did it function by you. regards cumulus |
Learn more about visualization - visit the HMI courses of Siemens AG! |
2/25/2009 6:00 PM | |
Hi loritod I tryed your settings, i hope. i had on the "start picture" a picture window, whitch shows an other picture as independent window. displayis "no". i get your settings? I never hadyour problem,i tried a lot. Has the property "miscellaneous" > "PictureName" the picture name? set this property by script too. sorry i don´t how i can help you regards cumulus |
