1/23/2012 12:26 AM | |
Joined: 10/7/2005 Last visit: 6/3/2023 Posts: 2966 Rating:
Hello Giuliano69 you are correct, it isn't possible to do open a DI "directly" when BLOCK_DB is used as a FC parameter. As a"faster or cleaner" method to your indirect way, you can usethe "CDB" command (swap DB1 and DB 2 registers) which would look as followed in your example case: OPN Block_DB1 // Block _DB1 parameter is opened as "DB via DB1 register CDB // Swap DB1 and DB2 register --> Block _DB1 parameter is now open via DB2 (DI) register I hope this helps |
Cheers |
