9/14/2013 7:07 PM | |
Joined: 1/28/2009 Last visit: 1/19/2025 Posts: 6858 Rating: (1366) |
That should not be that difficult: [code]NETWORK TITLE = CALL RD_SYS_T {date_type := 'Date_And_Time'} ( RET_VAL := #TEST , OUT := #ZEIT ); CALL BLKMOV {blk_type := 'Any'} ( SRCBLK := P#L20.0 BYTE 8 , RET_VAL := #TEST , DSTBLK := P#DB1.DBX0.0 BYTE 8 );[/code] tell us which version of TIA Portal you are using?Also check the following topic. |
Last edited by: hdhosseini at: 9/14/2013 7:26 PMLast edited by: hdhosseini at: 9/14/2013 7:09 PM |
9/15/2013 9:13 PM | |
Hello, For dynamic addresses in source and target area for SFC20,You can check the following samples for STEP 7.I am sure they can be easily adapted to TIA Portal. Dynamic (Variable) Any Pointersolution provided by fritz.Please help me with this FC out parameter with ANY typeBest regards Hamid Hosseini |
