5/15/2008 6:14 AM | |
Posts: 2661 Rating:
Are you using VMWare? |
5/15/2008 1:28 PM | |
Posts: 10 Rating:
No, I don't use this... |
5/19/2008 2:09 PM | |
Posts: 1776 Rating:
Hi, do you load the project locally or via network? try to create a new project locally, close and open the project. Does it take also the same long time? |
5/19/2008 4:15 PM | |
Posts: 10 Rating:
Hi, it loads the project localy.It would be good If I could at least fully open WinCC explorer before the project start loading in the middle of the process. |
5/29/2008 7:52 PM | |
Posts: 10 Rating:
Well...I am not sure yes..but I am starting to believe it has to do with the size of the Database that was aournt 1.8GB ! |
