1/5/2007 3:17 PM | |
Posts: 3149 Rating:
Hi, have you seen this actual for Wincc flexible Runtime: http://support.automation.siemens.com/WW/view/en/23719163 WinCC flexible ES needs this operating systems http://support.automation.siemens.com/WW/view/en/23510090 http://support.automation.siemens.com/WW/view/en/22927119 nemo |
1/8/2007 1:58 PM | |
Posts: 3149 Rating:
Hi, which Panel are you using (I guess a Panel PC477?)?? Did you already install WinCC flex RT on your Panel? nemo |
1/9/2007 2:30 PM | |
Posts: 3149 Rating:
Hi did you already install the latest Hotfix?? http://support.automation.siemens.com/WW/view/en/24376196 Did you install the ProAgent license ProAgent_for_PC_2006? nemo |
