11/19/2015 9:19 AM | |
Posts: 7 Rating:
Hi,
Kind Regards. |
11/19/2015 10:21 AM | |
Joined: 5/12/2006 Last visit: 1/30/2023 Posts: 21199 Rating:
Hello, for this module you should use a CU320-2. Here you can choose between CU320-2 DP and CU320-2 PN, the CU320-2 DP can extend with a CBE20 for PROFINET, the CU320-2 PN have PROFINET Onboard but no PROFIBUS. Note that you also need a Line Module for this drive Systenm for the DC Bus of the Motormodule, the motormodule can't wired directly to the AC Power! You should use the tool Sizer for Siemens Drive to design the system and find the right components and cables and so.
Christoph |
11/19/2015 11:01 AM | |
Posts: 7 Rating:
Thank you for you answer ;) When I will finish, I'll show you my configuration if that suit you to check quickly ;) Thanks |
