5/11/2023 2:41 PM | |
Posts: 5 Rating:
Thank you for your fast response. You'll find the screeshot of my screen attached to this message. |
5/12/2023 1:04 PM | |
Joined: 8/3/2009 Last visit: 4/25/2025 Posts: 15355 Rating:
Hello U_fc4321ee-96d8-4... I would try this: https://support.industry.siemens.com/cs/de/en/view/109778709 often this behaviour is only an inconsistency in the RT data. If this is not the solution for you then It would make sense to open a Service Request, perhaps your project has a defect. Bye Murof |
5/15/2023 6:59 AM | |
Posts: 5 Rating:
Thanks for your help !! It works !! i can go back to work !! |
