9/27/2022 12:56 PM | |
Joined: 6/19/2019 Last visit: 10/29/2024 Posts: 705 Rating: (77) |
See page 392 on this LINK B.2Spare parts-replacement fans try to remove fan and check it or it's working, if broken replace it. Then motor running fan must work together. What about your electrical cabinet temperature? maybe fan working but your cabinet temperature too high? and it cause V20 fault? do you have ventiliation on your electrical cabinet? Do you keep mounting clearance? from top and bottom at least 100mm for cooling? Also see what your F04 will cause: |
9/27/2022 1:15 PM | |
Joined: 8/24/2022 Last visit: 9/28/2022 Posts: 5 Rating: (0) |
P335 is set to 0 |
