1/4/2023 8:24 AM | |
Joined: 4/8/2021 Last visit: 4/25/2025 Posts: 640 Rating:
Hi Tomshcuu, Do this happen only with that tag and I/O field? Have you tried to creat a new I/O field with the same tag and see if same happens? I would also follow the next FAQ as it worked for many times when strage behaviour during runtime occured. https://support.industry.siemens.com/cs/ww/en/view/109778709 Hope it helps |
Best regards, |
1/4/2023 8:58 AM | |
Joined: 3/4/2021 Last visit: 3/24/2025 Posts: 16 Rating:
Maby there is a problem with your sensor. You can check this by creating a trace to see if the tag sometimes goes to 0.0. |
