5/23/2023 6:50 AM | |
Joined: 11/25/2022 Last visit: 7/26/2023 Posts: 12 Rating:
I have an IoT 2050 basic FS:04, should I first install the firmware V1.1.1 and then V1.2.1? Finally, can I also install V1.3.1? Thank you very much Best regards ------------------------------------------------------------------------------------------ |
Last edited by: loveflowersx at: 05/23/2023 07:19:18Last edited by: Jen_Moderator at: 05/23/2023 09:23:06New subject after splitting |
5/23/2023 12:45 PM | |
Joined: 12/16/2021 Last visit: 8/22/2023 Posts: 126 Rating:
Hi loveflowersx, How to setup the IOT2050 v1 and it version upgrades with Example Image here Regards
Last edited by: Jack0004 at: 05/23/2023 12:46:48If The Information Helpful, Then Don't Forget Give (To thank ) and Rate It |
5/25/2023 12:10 PM | |
Hi loveflowersx 🎉 For V1.1.1 do refer the setting mentioned in post here For V1.3.1 check out node setting through guide post here Thank you Regards.
