5/10/2022 1:54 PM | |
Joined: 4/28/2015 Last visit: 12/11/2023 Posts: 3298 Rating:
Hi, the logs come from node-red, probably from the s7 node. Hard to say why it is logged from the screenshot. As first try you could change the log level of node-red. Therefore change the level to e.g. error in the file /root/.node-red/settings.js (details see here) Best regards! |
5/11/2022 8:04 AM | |
Hi, okay. Could you provide your flow? Best regards! |
5/11/2022 6:28 PM | |
Joined: 3/3/2016 Last visit: 10/19/2023 Posts: 19 Rating:
Hi Bergmanu, thanks for your answer. I have attached my flow with the S7 node. The flow reads about 70 variables from a S71200 PLC and write that values to an OPC UA Server Thanks for your help Attachmentflows.zip (291 Downloads) |
