6/24/2021 10:34 AM | |
Posts: 2 Rating:
Hi, I am stuck at boot too. Siemens OS was preloaded, but I wanted to install the example image. While I was copying the .img from an sdcard to eMMc, the IOT2050 was stuck at some point. I turned the IOT2050 off and now it won't boot. With the micro SD inserted, the uart debug says:
Without micro SD, the following output is given:
When I want to boot from an USB stick, it won't work. The IOT2050 won't recognize the USB. I tried everything here and I can't come up with something else I can try right now. Can someone help me out? Thanks in advance! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 06/24/2021 12:18:39New subject after splitting |
