8/17/2021 5:11 PM | |
Joined: 10/15/2018 Last visit: 8/10/2022 Posts: 1 Rating:
Hello, I need to find the Linux command to create a backup of the eMMc of IOT2050 to a USB stick. I found the following application example to install the example image on eMMc, but I need the other way around. How to install Example Image to eMMc "dd if=/home/IOT2050_Example_Image_V1.0.2.img of=/dev/mmcblk1 bs=100M conv=fsync status=progress" Should I simply use "dd" command the other way? If so, how? I need help please. Have a good day! Best regards, Hugo_D |
