5/18/2022 5:54 PM | |
Joined: 4/4/2022 Last visit: 7/19/2022 Posts: 15 Rating:
Hi, I also have the same problem, I used iot2050 advanced to connect the power and monitor, the power light is green. STAT is green at first and then it will turn red, and the monitor is not receiving signal. I pressed Reset and STAT will turn green briefly and then turn red again. How can I solve this problem? best wishes FürBA ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 05/19/2022 09:43:38New subject after splitting |
5/19/2022 2:33 PM | |
Joined: 4/28/2015 Last visit: 8/16/2022 Posts: 2907 Rating:
Hi, did you write the Example Image V1.2.2 to the SD card with Win32DiskImager like suggested in the setting up? And the STAT LED stays off or is it blinking green afterwards? Best regards! |
