1/29/2014 9:20 AM | |
Joined: 10/18/2012 Last visit: 8/21/2024 Posts: 225 Rating: (23) |
Hello jebril, you can find the available operating systems for IPC277D at Siemens Industry Mall. Select "Configurators" and start the configurator to see which operating systems are possible. To verify what operating systems are compatible with your WinCC version you can check incompatibility toolat www.siemens.com/kompatool. First select your WinCC and service-pack version and continue to next step. In second step you can select the operating system in the product tree at the left of your browser-window. Select "all versions" for the os to get all available compatible os versions with your wincc version from step 1. And finally, keep in mind the hardware requirements of your software. To get a rough feeling about this see section "Optional operating systems" at http://support.automation.siemens.com/WW/view/de/63033297. regards, xnor |
1/31/2014 2:00 PM | |
hi jebril, you'll need an external USB-DVD-reader to read from the Setup-DVD, or you must copy the setup files from the DVD to a large pen-drive and start the setup there. Also keep in mind, that the support of windows XP will end soon. See this article: http://support.automation.siemens.com/WW/view/en/82555422. have a nice weekend! xnor |
