9/17/2015 3:41 PM | |
Posts: 24 Rating: (0) |
Thank you for your answers.
Another question: 1/4d-Zero Are this bit being set only when I do a zeroing or are the bit set when the weight value drop below a curtain value(close to zero)`?
Best Regards
Last edited by: CS Moderator at: 9/18/2015 2:49:55 PMNew subject after splitting |
9/21/2015 1:10 PM | |
Posts: 206 Rating: (22) |
Hi Walock,
the 1/4d-Zero signal of the Siwarex M indicates the weight value is zero +/- 1/4 of the set resolution of the scale. Regards ABenno |
