6/21/2013 11:30 AM | |
Posts: 1064 Rating:
yes when you cycle the power the eeprom is loaded over writing your changes . you need to write the changes to the eeprom |
6/21/2013 12:07 PM | |
Joined: 4/22/2010 Last visit: 12/15/2022 Posts: 5697 Rating:
Hello, Attached you find more information about the Cold-restart procedure of a S5-115 CPU. That should make clear why you need to load the program to Eeprom after changes. Regards, Marcjan Attachmentcold restart.pdf (238 Downloads) |
Problem solved? |
