8/18/2014 10:30 AM | |
Joined: 11/29/2011 Last visit: 2/2/2023 Posts: 1346 Rating:
Hi, If you use a VBa script I think it is possible, but VBa is for automateconfiguration steps. I mean like adding a tag prefix to specific object properties in the picture objects. See this topic: Also plenty of information in this manual: http://support.automation.siemens.com/WW/view/en/37572697 Cheers: |
- What you read here, please check with manuals and your requirements. |
8/18/2014 1:53 PM | ||
Hi, I see what do you mean. In this case you do not need to use VBA. Actually what you need to do is create the object on your screen, and acces to its "visible" object property. See the example bellow. The only difference is that you want to make a rectangle visible not a picture window. It should be accessable.
This example is from: http://support.automation.siemens.com/WW/view/en/37572697 You should find plenty ideas there. Any question please do not hesitate to ask! Let us known how you getting on! Cheers: |
8/23/2014 7:18 AM | |
Posts: 49 Rating:
Hi I figured out about this way myself, but I want to know is there any other way in Scripts or not Regards
