12/23/2024 10:38 AM | |
Joined: 11/13/2018 Last visit: 1/30/2025 Posts: 80 Rating:
Hello UHS_EkiZuzaeta, You can dynamize the tag of a Faceplate by selecting tag parameter. More info in this help article: Dynamizing an object property using a tag parameter. If that doesn't provide the capability you need, you can modify the tag from inside the Faceplate with JavaScript. More info in this help article: FaceplateContainer.Properties. |
Like it? Rate it! |
