3/22/2021 8:45 PM | |
Joined: 8/23/2016 Last visit: 8/10/2022 Posts: 4 Rating:
Hi, Is it possible to delete automatically log , once reaches to certain numbers , means FIFO concent in Logs , e.g. once logs reaches to 10 number , the first log deleted . ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/23/2021 09:10:51New subject after splitting |
3/23/2021 7:42 PM | |
Joined: 3/2/2016 Last visit: 11/30/2022 Posts: 72 Rating:
If you are using DataLogs function blocks, you can choose how many records you want to register in "RECORDS" input. If the "DataLogWrite" instruction writes more records than specified in this parameter, the oldest record is overwritten. Hope it helps! |
