3/14/2011 2:17 PM | |
Posts: 1 Rating: (0) |
Hello, I have a same problem. I want to connect the Omron PRM21 (Master unit) and CPU315-2DP (as slave). The configuration seems ok on Omron's side (Cx-configuratorFDT) but problem is with data consistency. The BF is flashing and SF lit. On Omron side BF is flashing, other are green. My question is: Is it possible to direct connect Omron PRM21 and Siemens CPU314-2DP (as slave) without using the DP-DP coupler ? thanks. Splitted from problem when connecting this OMRON PRM21 to Siemens CPU315-2DP as slave. |
