2/8/2016 8:14 PM | |
Joined: 11/29/2011 Last visit: 2/20/2023 Posts: 1347 Rating:
Hi, The deadband is like a tolerance, you can specify the width. See the Standard PID Control manual under chapter "4.3.1 Filtering the Signal with DEADBAND Function". Anyways if you desperately want to have a solution see the above manual under chapter "4.1.4 FC Call in the Setpoint Branch (SPFC)". Just an idea: Create an FC what help you to offset the SP within the deadband. Why do you need this function? |
Last edited by: MicroMan at: 2/8/2016 10:51:13 PMLast edited by: MicroMan at: 2/9/2016 9:53:09 PM- What you read here, please check with manuals and your requirements. |
