11/17/2006 7:55 AM | |
Posts: 433 Rating: (48) |
Hello Najafabadipour, J_Bell means this faq What compatibility does SIMATIC WinCC V 5.x have? and this faq With what is SIMATIC WinCC V 6.x compatible?. Tomcat |
11/17/2006 10:14 AM | |
Posts: 5822 Rating: (412)
Thank you Tomcat, you are right, I took the wrong Entry IDs... [:blush:] Thanks again J_Bell |
11/19/2006 8:18 AM | |
Posts: 25 Rating: (0) |
Hi, Thank youbut can someone help me about BCE license? Best Regads, B.Najafabadipour |
11/26/2006 4:25 PM | |
Dear Sirs, Thank you for your helps but I still hope someone help me more on using BCE license. Best regards, B.Najafabadipour |
12/2/2006 7:40 AM | |
Dear J_Bell, First of all thank you for your helps. If I use an AUI to RJ45 converter (same as what I found infollowing link http://www.alliedtelesyn.com/products/details.aspx?141) then can I use an ordinary switch hub (or simple hubs) instead of the star cuppler hub? Best regards, B.Najafabadipour |
