3/12/2023 7:21 PM | |
Posts: 4 Rating:
Hi, I'm experience the same kind of problem. I'm using WinCC Unified PC V18. I've noticed that if I create a faceplate and pass a value via the Tag interface the trend view works fine. However if I pass a UDT via the tag interface and try to trend a member of this UDT within the faceplate it doesn't work. Is there a way to trend a member of a UDT in a faceplate? Best regards, /erikW ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/13/2023 10:34:38New subject after splitting |
