9/13/2023 2:21 PM | |
Joined: 6/26/2023 Last visit: 4/17/2025 Posts: 6 Rating:
Is there any specific documentation for using AuditViewer? When I create a query to filter by date it doesn't work, I don't know if it's a date format error, apparently not. When I create a query for another value, for example "old value" it works normally.
Last edited by: Jen_Moderator at: 09/14/2023 07:45:43New subject after splitting |
9/15/2023 11:42 AM | |
Joined: 5/6/2022 Last visit: 4/16/2025 Posts: 585 Rating:
Hi @AutoGen_605389, From what I have been able to investigate, for the configuration of the Audit you can see this part of the manual that may still help you: Then, regarding the control of the audit viewer, the manual does not give much detail, but I am sharing it with you in case it could offer you some more information: I hope some of this information can be of help to you.
