7/9/2013 9:18 PM | |
Joined: 8/27/2006 Last visit: 10/22/2024 Posts: 719 Rating:
I was wondering about failsafe digital output modules what is special aboul them? dignostics? If I get for a 32 digital output module a 32 digita input module and I wired the each digital output signal to a digital input channel (i.e. Q0.0 -> I0.0, Q0.1 -> I0.1, ...etc) as well as connecting them to their field devices (relays, valves,...) In this way, I can diagnose a channel by channel for the digital output module, and if one digital output channel is faulty I will know for sure. The question is : Is this considered a failsafe digital output module?
The more you know, The more you know that you don't know |
7/10/2013 12:29 AM | |
Joined: 5/28/2008 Last visit: 3/24/2025 Posts: 4520 Rating:
Hello, No it is not a fail safe system. coz you did made all tests and you did not used certified blocks as well. |
Ayman Elotaify |
7/10/2013 7:22 AM | |
Yes, but I saw this technique is been used in old failsafe Step5 PLCs (e.g. CPU115F). The failsafe 16 digital output is divided into two halfs. 16 DO and 16 DI. The output is connected to the input as well as the field device. This module itself is described as 16DO failsafe.
7/10/2013 10:36 AM | |
Hello Ahmed, I do not have experience with S5-Fail Safe Systems. And I am not sure that the above behavior is the ideal or best engineering.
Ayman Elotaify |
7/10/2013 11:03 AM | |
Joined: 3/24/2009 Last visit: 7/9/2024 Posts: 535 Rating:
Dear AMAZINGAHMED, I also think, that you will have to do much more to prove the safety of your plant, as when you use certified F-IO modules, which have a lot of integrated background-tests (here an article for sinamics) Best regards, yy1 |
To explore the new Forum, you can follow the textbox in the right column, which will lead you to the corresponding page in the new Forum. Alternatively, you can start from the main page by following this link:
https://sieportal.siemens.com/en-ww/support/forum
In the coming days, we will update the configuration step by step, so that you are directed to the new Forum by default. The “classic Forum” will remain available for all known functionalities alongside the new one.
We are thrilled to finally share the future of our Forum with you. Thank you for your commitment!
Kind regards,
the Forum Support Team
