7/30/2010 1:32 AM | |
Joined: 7/28/2010 Last visit: 7/16/2023 Posts: 184 Rating:
Hi, I highly recommend you use an isolator for reading that analog signal as you are stepping down the voltage from 105V to 10V. Isolator will prevent any damage happens to your CPU in case something goes wrong with that tachogenerator. I have a post on my blog “Isolation for PLC Analog Input and Output Cards” explaining the different methods of isolations and where you can find isolators for your application. Regards, Behnam |
