2/22/2020 3:18 PM | |
Posts: 2 Rating: (0) |
We have an issue with cursor key and SWITCH function on LOGO 12/24RCE. We have tried to program cursor key C1 to switch Q1 ON/OFF by using "SWITCH" setting on C1 Simulation works fine. However when function is tested on actual device, Q1 works only while C1 is pressed. Other settings for C1 do not help either. We need to switch Q1 on when C1 is pressed and OFF when C1 is pressed again. How can we make C1 to work as a switch for an output? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 02/24/2020 06:33:22New subject after splitting |
2/24/2020 11:16 AM | |
Thank you, problem solved
2/24/2020 11:19 AM | |
Joined: 12/18/2014 Last visit: 1/18/2025 Posts: 34503 Rating: (4306)
That sounds good... |
