10/18/2021 4:34 AM | |
Joined: 1/5/2016 Last visit: 9/9/2024 Posts: 2 Rating:
Need help! Wincc RT professsional, On server PC Text list display is no problem, but in client's PC, Text list display is '***'. Don't know how to settle the problem. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/18/2021 12:31:56New subject after splitting |
10/18/2021 7:11 PM | |
Joined: 8/12/2020 Last visit: 3/4/2025 Posts: 41 Rating:
Hi, First of all, check the compatibility between WinCC and your SO. You can check the compatibility with Compatibility Tool. In other hand, is it a web client? What lenguage do you have selected in Windows on you client PC? Br, Hugens |
5/5/2023 8:45 AM | |
Joined: 11/12/2019 Last visit: 12/6/2024 Posts: 14 Rating:
Hi, I have the same problem. Is there any solution for this? Best Regards Saba |
5/12/2023 9:27 AM | |
Hello thin client? so do you work with a Client and your thin Client works with VNC or RDP on the Client? or do you use any web option like Webnavigator or WebUX directly on the thin client? Try a reset of the dcf file, perhaps it helps: https://support.industry.siemens.com/cs/de/en/view/109763043 Bye Murof |
