7/3/2014 10:18 AM | |
Joined: 4/24/2006 Last visit: 1/20/2025 Posts: 8808 Rating: (1173) |
Hello jaffar, Perhaps the following links might help: how do you restart a PID controller that has been stopped because of a scan time error or switch off the scan time monitoring? how can you prevent the PID Compact controller of the S7-1200 from switching off when the controller is switched off and on again and in the case of invalid process values? Best regards, Wizard |
8/24/2014 3:44 PM | |
Posts: 6 Rating: (0) |
thanks Marcjan : i will try this...
3/28/2016 11:44 PM | |
Posts: 1 Rating: (0) |
why you don't use thes function scale and move? after that you compare the result to the max to stop ur system I think that's much easier then PID. |
3/29/2016 11:29 AM | |
Posts: 129 Rating: (17) |
check post's date.. it's 2 year old post brother |
