5/17/2015 9:21 AM | |
Joined: 1/21/2013 Last visit: 11/20/2024 Posts: 4620 Rating:
Hello, If your panel still function, you can try with Prosave and the respective cable: https://w3.usa.siemens.com/us/internet-dms/ia/AutomationComm/Automation/Docs/ProSave_e.pdf http://support.automation.siemens.com/WW/view/en/10347815 http://support.automation.siemens.com/WW/view/en/26588748 https://www.automatyka.siemens.pl/docs/docs_ia/Panels_Possibilities_of_connections_PL_EN.xls |
Last edited by: Ste39 at: 5/17/2015 9:37:39 AMLast edited by: Ste39 at: 5/17/2015 9:39:00 AMLast edited by: Ste39 at: 5/17/2015 9:41:54 AM |
5/17/2015 9:52 PM | |
Joined: 3/28/2015 Last visit: 2/1/2025 Posts: 722 Rating:
Hello, Transfer mode in OP7: Press and hold the keys 'ESC' and 'Cursor Up' while turning on the power supply of the panel . Attention: If you press the keys' ESC' + 'Cursor Right' +' Cursor Down' you will go to Transfer mode, but also delete the project in the panel Kindly find the attached file for the Communication cable between HMI and PC. |
Eng.Mohamed Ibrahim |
6/20/2015 11:41 AM | |
Yes,you can restore the program from 0AX1 to 0AX2 with Prosave 6AV3607-1JC00-0AX1Successor product: 6AV3607-1JC00-0AX2 |
