3/6/2011 4:34 PM | |
Joined: 7/2/2008 Last visit: 8/26/2024 Posts: 928 Rating: (308)
Hello Tomy Master, Check the difference in, Where and when do you need peripheral addressing? You can write IW as long as the address lies inside the process image. For example this CPU can address 1Kbyte so you can write PIW512 but its process image is limited to 128 byte which means you can't write IW512but you can still write up to IW127. Best regards. H-H |
