4/3/2018 9:17 AM | |
Joined: 4/28/2015 Last visit: 2/3/2023 Posts: 9027 Rating:
Hello, look to web generally to be familiar to what system you step... |
With best regards... |
5/31/2018 11:44 PM | |
Posts: 5 Rating:
Hi, generally, not only in automation, the JavaScript is the choice to go. It is not widespread in automation, but it will become in near future. There is an automation platform called mySCADA which uses JavaScript as the scripting language, also for the server side scripting, it uses node.js choice of many large companies. You can do miracles with it. Check it here mySCADA I have made same complex project in mySCADA interlinking over 30 PLC, with advanced datamining and predictive maintenance so I have quite some experience. You can drop me an message for more info :) cheers Dan |
